BUSINESS OWNERS
modules Chile
Save fuel with Solar Diesel Hybrid Systems
Save money with photovoltaics & diesel generators
In combination, diesel generators and photovoltaic systems are very well suited to energy supply in areas with an unstable or non-existent mains supply. The additional use of solar energy reduces fuel consumption, which saves costs. Furthermore, the integration of a PV system brings a sustainable factor into the system.
Advantages of solar diesel hybrid systems
  • Reduce diesel costs – Solar power is much cheaper and more predictable in the long term than power generated by diesel generators.
  • Quick ROI – Due to the high savings potential, the investment in a photovoltaic system pays for itself after a short time.
  • Reduce CO2 footprint – Generating solar power reduces your carbon footprint.
modules in Christiana
Save fuel and reduce energy costs
Fuel costs make up the largest part of the cost of producing electricity using diesel generators. Depending on the geographical location, oil prices of up to €2.5 per kWh can be expected. This shows no sign of abating.
The price trend in the photovoltaics sector is much more positive. Over the past few years, the costs per kWh from PV systems have dropped to an average of €0.10 per kWh around the globe.
For this reason, there is a clear financial justification for converting almost every diesel-powered system into a solar/diesel hybrid system. Every unused diesel kWh saves money.
inverter Christiana
An investment that pays off quickly
The combination of diesel generators with PV systems quickly pays for itself through the large savings in fuel costs.
Intelligent technology ensures optimum interaction between the photovoltaic system and the diesel generator. This guarantees that as much solar energy as possible is used and that the diesel generator operates at various degrees of utilisation at the most advantageous operating points.
How a solar diesel hybrid system works
Photovoltaic modules Modules can be mounted on large roofs or in open spaces and generate solar power when exposed to the sun. This electricity must be converted from direct current to alternating current before it can be used. The inverter is responsible for this.
Inverter The inverter is the control centre of every photovoltaic system. It converts the generated direct current into alternating current and provides the self-contained network (MicroGrid) with as much solar power as possible.
PV system controller The Fronius PV System Controller measures all energy flows in the PV/diesel system, enabling it to control the photovoltaic power in the most optimum manner.
Diesel generator The diesel generator is the primary energy source for solar/diesel hybrid systems. The more solar power can be generated, the lower the fuel costs.
Loads The loads are supplied with a mix of solar energy and fossil energy through the combination of a diesel generator and photovoltaic system.
5
Current sensors The current sensors are connected to the PV system controller and measure the power in the system.
6
Backup feedback contact The feedback contact (grid supply) facilitates the operation of the photovoltaic system – optimally adapted to any energy fed into the grid or parallel generator events.
7
Grid A connection to the grid can be available at least temporarily.
8
Inverter
Diesel generator
5
Loads
6
Current sensors
7
8
Grid
modules in Zimbabwe
Reduction of diesel costs through the use of photovoltaic energy
„During the day, the owners of the tobacco factory are able to cover a large proportion of their energy requirements with solar power, both in the high and the low season. If less tobacco is produced, the farm feeds more energy into the grid. The owner thereby has an additional source of income and becomes a „power farmer“. He uses less diesel and saves thousands of euros annually. Thanks to these savings, the system will have paid for itself within a few years.“
Muhammed Seedat, Technical Consultant at Fronius
See the reference
HIGH QUALITY, WORTHWHILE INVESTMENT
  • Smart technology
    The intelligent Fronius inverters ensure that electricity from photovoltaic systems can be used particularly efficiently.
  • 75 years of experience
    More than seven decades ago, Günter Fronius founded the family-owned enterprise. Now the team is made up of 5,000+ people, and together they are driving forward the energy revolution.
  • Made in Austria
    Fronius quality has always been produced in Austria. Sustainable production is particularly important to us.
  • Strong partners
    A Fronius partner near you – trained & certified by us – is available to help you with advice and support for your personal energy revolution.
To ensure stable operation of a solar diesel hybrid system, optimum control of the integrated components is essential. This is only possible through the use of high-quality and sustainable equipment.
As a quality manufacturer that carries out research and production in Austria, Fronius sets the highest quality standards and builds on more than 75 years of experience. Open interfaces and continuous further developments ensure ongoing improvements and solutions that can be used flexibly in the future.
Our Fronius System Partners around the world will be happy to help you plan and implement your individual solar/diesel hybrid system. Our certified partner installers are competent contacts for planning, installation and service. If repairs are necessary, local Fronius System Partners with in-depth knowledge and spare parts in stock are on hand at all times. Our close-knit network of partners thus guarantees the fastest service even in structurally weak areas, which reduces yield losses to a minimum.
